AbelM
- Dec 28, 2001
I have a setting on my reciever that is named D Range..I have choices of Max, STRD, or Low
Yeah I have the Yamaha RX-V520. So I should just leave it at Max, right?
Yes, if you want to experience the full dynamic range DVD has to offer. Setting it to MAX in your particular case will not implement any dynamic range compression on the soundtrack.
I would suggest playing a scene from a DD 5.1 title with lots of explosions and loud peaks.
Try the different DR settings and hear for yourself how it affects the sound.
