DannyL
- Dec 18, 2001
i just purchased a d-link di-614+ router with a dwl-650+ pc card for my vpr matrix laptop running windows home xp. i plugged my verizon dsl into the router and followed all the instructions to add the pc card to the laptop. the router itself seems to be working because i can surf then internet via the ethernet cable.
here's my problem. with the basic installlation the wireless pc card works fine. however, the pc card utility program will not run on my computer- meaning i can't change any of the encryption parameters. i've called d-link technical support five times and i've tried everything from uninstall/reinstall to disabling the windows xp wireless management (which completely screwed up everything and required restoration) to installation of a newer pc card driver (which is the latest problem because now the pc card doesn't work at all now). someone please help me; i'm pretty computer illiterate. thanks.
