CyberHome CH-DVD 500- Comments?
Discussion in 'Playback Devices' started by Zach Foster, Mar 2, 2004.
  1. Zach Foster
    Zach Foster Stunt Coordinator
    Jun 23, 2003
    59
    Wow, now this little 'ol DVD Player feels out of place on a page full of threads about Denons, etc, but I was wondering if anyone has any experience with a CH-DVD 500. More specifically, in regards to the hookups they use. I have what I consider to be a fairly good TV (A nice RCA 27 inch flat screen) and currently I have my Player hooked up to it via standard A/V cables. My TV produces a great picture, but I have noticed that via A/V cables, I see "ghost lines" from the DVD Player whenever a movie has scenes that are in black. Should I upgrade to component video cables for the Player? (The RCA has component video ins) I know that on average, you cannot go wrong with component cables, but I was just wondering what people's experience was, in using those cables on a CyberHome. On such a cheap player, would it benefit by using components? Would it eliminate my "ghosting"? Or is that just inherent on this cheap player? I will go to components if it truly will make a difference, but if not, I'll just grit and bare it. Any ideas? Thanks in advance!
  2. Kevin. W
    Kevin. W Screenwriter
    Oct 27, 1999
    1,534
    Goto your local CC and get some component cables. If it looks better keep them otherwise take them back.
    Kevin
  3. Chris_Cur
    Chris_Cur Agent
    Dec 1, 2002
    47
    Does your tv have an s-video input open? I'd try that. S-video cables are cheaper than component cables, anyway.
    I've got to say that for every regular 27-inch or smaller TV I've seen, there isn't a great deal of difference between components and s-video. The quality jump from composite to s-video is almost always incredible. On most smaller TVs, the jump from s-video to component isn't anywhere as noticeable.
    That's just my opinion, of course. YMMV.
  4. Zach Foster
    Jun 23, 2003
    59
    Yeah, I've thought about S-Video- I have my PS2 hooked up via components, so I guess thats the image I'm hoping to get from my DVD Player. Although, I wonder, since I've grown used to my PS2 on component cables, am I just expecting too much from my cheap player, and would be better off just getting S-Video? Thanks!
