matthew_rm
- Dec 24, 2001
- Real name
I have a Denon 2802, and while looking at the menu, I noticed that my main towers are "cut off at 80HZ." I also checked too make sure my main speakers were set to large. I can set my .1 too either LFE or LFE+Main. I do not know if the LFE option only effects movies or not, but it makes no change on my cut off. I also do not underatand why my reciever is cutting my towers at 80Hz. They are Klipsch RF3II's, and I used to have plenty more bass on my old setup. (2ch) I can notice less low end, even with 2 subs. (for music)
Does anybody know if Running in "Direct" will play my towers full range? I dont want too liston to music unless I know system is playing the way "I" want it too.
PS, I lost my manual
Thanks in advance for any advise.
Hope you understand my question
