Peter_J_B
- Apr 29, 2003
I just read the link on the 300 you posted, and was impressed. Mainly with the lesser extent of it's screendoor at closer range. Although, I do have a decent PC I'd consider hooking up. Or I have an older PC that I could gut if the components required in a HTPC aren't that high. Not sure what processor is required.
The only problem is that these FPs have short throw. Does this mean that I'd have the projector up in front then? Or can I still bring it back and keep the screen smaller than max? It is saying 9.8-12.2' for a 100" screen, and I was planning on sitting about 13-13.5' away. I could realistically go to a bigger screensize, considering I only arbitrarily picked 100". If I want it 14-15' away so it's a foot or two behind the main viewing area, then I could go to 120+", but not sure how the resolution would be. And then I'd have to find some cheap pulldown screen. I'd love to just make a stationary DIY screen, but unfortunately, my regular tv will be mounted behind the wall, so not sure what option other than a drop down is possible.
