John Williams
- Jun 30, 1997
Hello everyone!
This is a purely non-technical, fashion/decorating question that I thought belonged in here.
The room where I have my home theater set up has a set of windows on the end opposite the RPTV. There are three windows in the set, with a half-circle window over the middle one. The whole arrangement is probably close to 6 feet wide.
Right now, we have 2” plantation shutters covering the lower (square) windows, but nothing over the upper half-circle one. This looks nice, but doesn’t do a whole lot in the way of light control for the room.
So my question is: What can I do in terms of curtains, shades, etc. that will help control the light in the room a whole lot better than now? Whatever I come up with has to pass the SAT (Spouse Acceptance Test), and look nice.
I was thinking about a large curtain rod above the whole window set (including the half-circle window), with some kind of heavy curtain material….but I’m concerned that it would look a little weird (it is a very tall set of windows.) The final solution has to look nice open as well as closed, after all.
And on a related question…does anyone know of a source for light-blocking material that can be incorporated into curtains? Whatever we end up with in terms of a design, I think I have a line on someone locally to make it, so I’d like to be able to refer them to a particular material that works well.
Thanks in advance!
-John Williams
Thanks in advance!
-John Williams
