Curtain controller
Discussion in 'Home Theater Projects' started by greg_mc, Feb 13, 2004.
  1. greg_mc
    greg_mc Extra
    Dec 2, 2003
    24
    I am looking for a device to open and close curtains. Prefer something that is relatively quiet and can be used on IR remote so a Harmony SST-768 remote control will work with it. Any suggestions?
  2. SteveLeach
    SteveLeach Stunt Coordinator
    Nov 19, 2003
    159
  3. MikeWh
    MikeWh Second Unit
    Mar 3, 2003
    407
    Smarthome sells other controllers, in addition to the expensive, but apparently trustworthy Makita.
    http://www.smarthome.com/hvacdrape.html
    Several people here use this one, although they have mostly commented that it is not quiet:
    http://www.smarthome.com/3142.html
    I have not heard any comments on this one that is cheaper than the Makita:
    http://www.smarthome.com/3182.html
    Can't comment on your particular remote control issue-- except that it's probably much harder to just find a drape controller, than it is to rig up an IR capability for it. At worst case, you can use X-10 and IR to control them.
