Current RSP1066 Status? (1 Viewer)
TomH
I am still considering the 1066. I know that it has had its share of problems and upgrades. Have most if the issues been resolved?
Video bandwidth limitation is a design issue. Is it possible that the double or triple bass problem will be a SW fix? Is it comparable to the Outlaw bass problem?
If Outlaw has eliminated hiss from the 950, Is the 1066 really worth an additional $600.00?
Tom
Warren Hubbs
i believe the bass management issue in the outlaw & the 1066 is caused by the same chipset. forget who makes them....(used by both companies)...correct me if im wrong...
Ruavain
