Current HD Obsolete?
Discussion in 'Archived Threads 2001-2004' started by Max Malloy, Oct 4, 2001.
  1. Max Malloy
    Max Malloy Stunt Coordinator
    Oct 1, 2001
    71
    I heard someone mention something about all current HD hardware being obsolete because the standard was changed or something like that? Could someone clarify please? I was planning on getting an HDTV but i'm not so sure anymore.
  2. Jeff Leeds
    Jeff Leeds Stunt Coordinator
    Aug 10, 1999
    131
    First off, this is probably going to get moved by a moderator since this is the hardware area not HDTV. But since this is my 500th post (I had to post one more time before I crashed) I would say that the standard isn't going to change to the point where you would not be able to buy a new control box. I would buy an HDTV "Ready" set and you'll be in pretty good shape for the next few years at the very least. In the last 2 years there has been lots of confusoin around this, but I say go for it, it rocks.
    Jeff Leeds
    [email protected]
  3. Max Malloy
    Oct 1, 2001
    71
    Need more info still [​IMG]
  4. BradZ
    BradZ Stunt Coordinator
    Feb 19, 2001
    161
    OK, here is the short version.
    Current HDTV-ready sets have analog connectors to hook up to an HD receiver. Hollywood does not like that. They want a secure digital connector which they could somehow flag the signal to restrict how the end-user uses the signal. Basically this is a copyright issue. Hollywood wants to make sure that nobody makes pirate copies of HDTV transmissions. These new digital interfaces (primarily either firewire or DVI) would allow the studio, broadcaster, or whoever to allow no-copies, one-copy, or unlimited copies of a transmission.
    If one of these digital connectors eventually wins out, then any tv without those digital connectors could conceivably be made less-than-HDTV. The common consensus is that analog connectors would not be turned off, but rather down-rezzed to something like 480p. Which is better than NTSC 480i, but significantly less than HDTV's 720p or 1080i.
    So, in summation, no an HDTV won't be obsolete if digital connections come to fruition (which they eventually will), but current HDTV's won't really be HDTV on all signals. Remember, they'll still have the capability- it just depends on how the broadcaster/studios flag the signal. It's possible that most programs won't be down-rezzed, perhaps just PPV or premium movie channels.
    Should you buy? that's up to you. My advise is that if you really have the urge and there is plenty of HDTV in your area- go ahead. We're talking at least 3 years before any of these connection issues matter much. If you aren't sure or you don't want to buy a new tv in 5 years or so- wait a couple of years to see what happens with digital connectors and tvs start shipping with them.
    hope this helps.
    zaphod
    end of transmission...
  5. MickB
    MickB Agent
    Aug 31, 2001
    44
    BradZ said it perfectly.
