Greg Kennedy
- Sep 20, 2002
Hi, all. I successfully modified my CueCat to read barcodes normally. I just had a question about using this with DVD Profiler. I know someone mentioned this as one of the purposes, but unfortunately the barcode scans in a first and last digit on a DVD barcode that DVD profiler doesn't need. In other words, after you scan the barcode, you still have to go through and delete the first and last digits for DVD Profiler to recognize the DVD. Are there any work arounds to have the CueCat ignore the first and last digits?
Thanks.
Greg
Thanks.
Greg
