cue cat/dvd profiler help
Discussion in 'Archived Threads 2001-2004' started by Ken Wagner, Nov 25, 2001.
  1. Ken Wagner
    Ken Wagner Stunt Coordinator
    Feb 21, 1999
    84
    I hate to bother everyone but I can't get my Cat to work and I'm sure it's because my settings aren't set up. I thought I saw a post somewhere about this but didn't mark it and now I can't find it. I'm sure it's something really stupid. I would like to get it to work just to see if it is worthwhile. Thanks.
    By the way, I did go to Profiler's forum and Faq areas and it didn't help.
  2. Shawn Sefranek
    Shawn Sefranek Second Unit
    Sep 30, 1998
    258
  3. Ken Wagner
    Feb 21, 1999
    84
    Thanks Shawn. I did put in the info in that thread but I don't see anywhere on Profiler and add buttom. I must not have something right. When I scan a UPC it gives me feed back like it was successful but where did it go? Am I supposed to put in the URL for Profiler? I am really confused or dense or both.
  4. Shawn Sefranek
    Sep 30, 1998
    258
    Just to confirm, you ARE running the CATNIP software and not the driver that came with the CueCat ???
    Other then that, I can’t really help.
    I adjusted the settings as posted and mine works fine with no other mods.
    Shawn S
  5. Ken Wagner
    Feb 21, 1999
    84
    Yea, I downloaded Catnip and it seems to be running fine. Just don't know what to expect. When I get the chime that it scanned it shows the numbers in the window but then what? Am I supposed to put in Profilers web URL to it will add it? I guess I'll post the question on their forum to see what I'm doing wrong. Thanks for your help.
  6. Shawn Sefranek
    Sep 30, 1998
    258
    Start CATNIP and it will run in the background.
    Make sure you are online.
    Start DVDProfiler.
    Click “Add new DVD’s”
    After the new database is loaded...
    Make sure “use barcode” tab is highlighted
    Scan your new titles and hit enter after the number appears in the window.
    Then select “Add now” and the info will be downloaded from the net.
    That’s the best I can remember from here at work.
    Good luck,
    Shawn S
