Cue Cat, Cat Nip & DVD Profiler
Discussion in 'DVD' started by Vince Maskeeper, Oct 28, 2002.
  1. Vince Maskeeper
    Vince Maskeeper Producer
    Jan 18, 1999
    6,499
    Back in the day I used the free CUE CAT barcode reader to scan my DVD collection into profiler using a driver/app called Cat Nip. If I recall a HTF member had sent me the application way back when...
    I'd like to start using DVD profiler again- and rather than typing in 500 dvds by hand, I'd like to use the cue cat and cat nip again- only I can't find any info. If I recall, the cat nip software even has a small txt file which explained the best way to configure it to work with profiler.
    Anyone have any idea where I can find the app and info?
    -Vince
  2. Dmitry
    Dmitry Supporting Actor
    Nov 30, 1998
    740
  3. Andrea W
    Andrea W Supporting Actor
    Mar 19, 2001
    777
    I was under the impression that with DVDProfiler 2.0, you didn't need catnip because DVDP2 comes with a barcode scanner plugin. Now that I think about it, though, it might only work for neutered cuecats.
    I haven't scanned anything since upgrading to 2.0, so I could be wrong.
  4. Andrea W
    Mar 19, 2001
    777
  5. JohnBe
    JohnBe Auditioning
    Jan 10, 2000
    2
    The plugin in version 2 works fine. No need for anything else.
  6. Jim Skripchuk
    Mar 20, 1999
    21
    Was wondering if anyone had any luck with a cue cat and a USB keyboard? My Compaq has a USB keyboard, a ps/2 mouse port and a ps/2 keyboard port. I plug the cue cat in the available ps/2 port and the "cat" lights up. As soon as I try to scan a barcode, the mouse locks up and I need to reboot.
    I am running XP.
    Any help getting this to run with DVD profiler v2.0. would be appreciated.
    Jim
  7. Joshua Clinard
    Joshua Clinard Screenwriter
    Aug 25, 2000
    1,826
    70
    1,610
    Abilene, TX
    Joshua Clinard
    I want to order a Cue Cat from ebay, only all the available ones have been modified to send clear text, instead of unencrypted text. Does anyone know if a modified CueCat will work with DVD Profiler, and do I need Catnip, or does the plugin work? I'm getting a USB CueCat by the way.
  8. Dmitry
    Nov 30, 1998
    740
    It will work. You will not need CatNip, the plug-in in the latest version of the DVD Profiler will take care of the first and last digit of the full-text UPC code.
  9. Joshua Clinard
    Aug 25, 2000
    1,826
    70
    1,610
    Abilene, TX
    Joshua Clinard
    Thanks for the info, Dmitry. I guess I'm off to ebay!
