CRT Warped?
Discussion in 'Displays' started by Greg Kennedy, Mar 11, 2004.
  1. Greg Kennedy
    Greg Kennedy Agent
    Sep 20, 2002
    32
    Hi, all. I've had my 36" Sony Wega for a couple years now and something I've noticed is that when it plays a widescreen DVD, the picture on the left side of the TV seems to angle slightly downward. The picture looks great otherwise and I have no complaints in regular ole 4:3 mode. It's been like this for a long time. Anyone have a clue if this is a tube defect or any other ideas?
    Thanks.
    gk
  2. Jack Briggs
    Jun 3, 1999
    16,738
    129
    Your geometry is off -- common on flatfaced CRT-based designs. It's correctable from the service menu.
  3. Greg Kennedy
    Greg Kennedy Agent
    Sep 20, 2002
    32
    I'll check it, but I swear I have been through every menu my TV offers and never saw anything that allows me to adjust the geometry. I have a KV-36FV26.
  4. Jack Briggs
    Jun 3, 1999
    16,738
    129
    The service menu is different from the user menus you're thinking about. Accessing it requires a certain code, and once you get in, you have to be very, very careful. Your FV26 is a three-year-old model, and there may be other members here who can give you the access codes.
  5. Greg Kennedy
    Greg Kennedy Agent
    Sep 20, 2002
    32
    Ah.. I didn't catch the difference between menu and "service" menu. I'll start doing research. If anyone out there can give me more details about accessing the service menu for my TV, please share!
    Thanks!
    gk
  6. Gregg Loewen
    Gregg Loewen Video Standards Instructor, THX Ltd.
    Insider
    Nov 9, 1999
    6,374
    32
    6,610
    New England
    Gregg Loewen
    I suggest you purchase a service manual and follow the instructions for optimizing the geometry.
    best wishes
    gregg
  7. Robert Todd
    Robert Todd Agent
    Mar 5, 2004
    39
    Yeah, you can REALLY screw up your set if you go aimlessly poking around in the service menu. Do as Gregg suggested, even though you might find the code somewhere else.
  8. TomCW
    TomCW Second Unit
    Jun 4, 2002
    339
    110
  9. Greg Kennedy
    Greg Kennedy Agent
    Sep 20, 2002
    32
    Thanks for the link, Tom. I'm going to see how closely their setting abbreviations match my set and then if I can figure out what needs to be tweaked I might give it a shot.
    I guess my biggest problem is that unless I'm able to have a DVD playing while in the service menu then I won't be able to get the feedback to correct (or help me determine what knob does what). Does anyone have any suggestions for what I might be looking for to take care of the problem I described in the original thread?
    If you look at the list of setttings on this page: http://myweb.accessus.net/~090/sonyadj.html
    then you will see what my options are. I was going to play with UPIN (pincushion upper ends, vertical lines) or maybe some of the keystone corrections. It's really a guessing game right now and if I can't get feedback easily while doing it then I might have a problem.
    Thanks.
    gk
  10. TomCW
    TomCW Second Unit
    Jun 4, 2002
    339
    110
    Greg,
    I used the cross hatch test patterns in AVIA, along with the service manual to tweak the geometry on my 36" Sharp. Write down the settings before you mess with them so if something goes horribly wrong you can hopefully get back to where you are now.
    These settings would be the most likely to need adjusting for the problem you describe, IMO.
    PAMP 18 0-31 Pincushion Amp.
    CPIN 4 0-7 Corner Pincushion
    PPHA 7 0-15 Pincushion Phase
    UPIN 10 0-31 Pincushion upper ends, vertical lines
    LPIN 10 0-31 Pincushion lower ends, vertical lines
    PPHA 7 0-15 Keystone correction vertical lines
    HKEY 6 0-15 Keystone distortion, horizontal lines
    HTRP 8 0-15 Keystone correction, horizontal lines
    This guy has service manuals for most Sony stuff. I have ordered from him several times with no hassle.
    http://www.celica-dude.d2g.com/
    Tom
    PS. He has the manual for your set, $10
  11. Greg Kennedy
    Greg Kennedy Agent
    Sep 20, 2002
    32
    I just got the service manual and am flipping through it now. Again, thanks for the link. Hopefully this will have enough detail to solve my problem.
    Thanks again!
    gk
