CRT DVD Compatibility
Discussion in 'Archived Threads 2001-2004' started by Pat Kellett, Apr 18, 2002.
  1. Pat Kellett
    Pat Kellett Auditioning
    Apr 5, 2002
    7
    Just a quick note of thanks to Seldon et al about my image shake problem between the DVD player and CRT projector. The video stabilizer ($27 including shipping) solved the problem. Not bad, $27 to return ones sanity!!! I cannot thank you guys enough - I had no idea where to turn next. Pat
  2. James Bergeron
    James Bergeron Supporting Actor
    Oct 9, 2001
    831
    Was it just "shaky" or was it "rolling" and moving sideways?
    Or by shaky do you mean that you saw the picture but it kind of vibrated up down or something?
    Wondering because if it was "rolling" or whatever maybe all I have to do is buy one of those adapters, cause mine don't work either [​IMG]
  3. Pat Kellett
    Apr 5, 2002
    7
    James,
    Sorry mine was never rolling or moving sideways - just an annoying shake to the image every 5 seconds or so. Sounds like yours may be a different problem. Vertical or horizontal hold? Sync rate? These are my guesses which, I must worn you, are not worth much. Good luck, Pat
