BillGallagher
- Apr 8, 2004
Here's my situation:
1) Video Sources:
a) Denon 1920 (480i or 480p), S-Video, Component, HDMI out,
b) X-Box (480i), Component out,
c) HDTV tuner (720p or 1080i - yet to get tuner), assuming component out.
2) Receiver: Denon 3806 (S-Video, Component, HDMI in/out)
3) Projector: Sony VPH-1272Q (currently only RGBHV in)
I also have an older Deuce 2200 Intelligent Video Scaler with only S-Video In, and RGBHV out.
My dilema:
What is the best way to connect my sources?
Option 1) Everything into the receiver (for switching) and out as single S-video (limited to 480i) to scaler, scale everything up, and then RGBHV directly out to projector. Total Cost = $130.00 (30' RGBHV Cable)
Option 2) A Sony IFB-12 component input card for my projector (that may or may not be capable of 720p/1080i) and using my receiver to switch between video sources. Everything connected using component. Total Cost = $200.00 ($69 card + $130 cable)
Option 3) A Moome IFB-M2005A+ component/DVI input card for my projector (that is capable of 720p/1080i) and use my receiver to switch between video sources. Everything connected using component. Total Cost = $310.00 ($180.00 card + $130 cable)
Option 4) A $180.00 Moome IFB-M2005A+ component/DVI input card for my projector (that is capable of 720p/1080i) and use my receiver to switch between video sources. Everything connected using HDMI (DVI to projector). Total Cost = $390 ($180.00 card + $210.00 cable)
Option 5) a Sony switch with 3 IFB-12*s (that may or may not be capable of 720p/1080i) - but then I get my receiver out of the loop. Everything connected using component. Total Cost = $340.00 ($210 switch w/cards + $130 cable)
Option 6) HDConnection HDC1.1 transcoder (capable of 720p/1080i) and use my receiver to switch sources. Everything to receiver as component, then use the transcoder to go from component to existing RGBHV on projector. Total Cost = $445 ($315 transcoder + $130 cable)
Option 7) a $800 DVDO HD+ video processor (capable of 720p/1080i and built in switch) and the Moome card. Everything component or HDMI/DVI Total Cost = $1,110 ($800 processor + $180.00 card + $130.00 cable)
Whew...that was a mouthful... I sure hope someone has a recommendation!
1) Video Sources:
My dilema:
