Brian Bunge
- Sep 11, 2000
The K2 has 2 input sensitivity levels. One is a 1.4V input which the manual says should be used for "full rated output" and a 26dB setting for "fixed voltage gain". Which of the two of these should I use? I'll be feeding both channels a mono signal from my subwoofer output and using the amp in stereo mode initially to power my dual 12" subs until I get my 1803 built.
Brian
Brian
