crossovers for dipole application?
Discussion in 'Archived Threads 2001-2004' started by Philip_G, Nov 7, 2001.
  1. Philip_G
    Philip_G Producer
    Nov 13, 2000
    5,030
    I'm beginning this project
    http://www.hometheaterforum.com/uub/...ML/003340.html
    and I'm planning to use 4 dayton 5.25's and 4 dayton 1/2" dome tweeters, but I'm not sure how to go about the crossover.
    the drivers are all 8 ohm, so I don't want to parallel them for 4 ohms or series them for 16, does anyone make a crossover for this application specially?
    edit.. oops meant bipole
    [Edited last by Philip_G on November 07, 2001 at 10:28 AM]
  2. James Mudler
    James Mudler Stunt Coordinator
    Feb 1, 2001
    207
    Check speakerbuilder.net. He has a two way x-o with the same drivers. You could build two networks per side and reverse the phase on one. Still will not solve the total impedance issue. Good luck
    Luke, I'm your father
