Aaron E. Smith
- Jun 9, 1999
- Aaron E. Willson-Smith
Ok, those of you who have read my messages are probably familiar with some of my equipment choices and tinkering, but I'll go over the whole enchilada to try to be clear. I use a Lexicon DC-1 with four Adcom GFA-555's (200WPCx2 each). My speakers are a Vandersteen VCC-1 for my center, Vandy 3's for my fronts, the side and rear pairs are Vandy 2Ci's and I've recently received my SVS 16-46CS.
So what is my quandary? Well, I used to have my Lexicon all set for LARGE speakers (except the center) with a 40Hz crossover to my old sub (a Hsu). I had done this because the Vandy manuals claim response down to 30Hz for the Vandy 3's and 32Hz for the Vandy 2Ci's, so the LARGE setting and 40Hz crossover seemed well withing reason.
Now on to the problem. Last fall I had been doing a demo for my brother-in-law. I turned on the equipment, popped in a DVD and started to raise the volume to listening level. This is when I noticed my darling little doggy chewing on the couch. I shooed him away, only to realize that I had left my finger on the 'up volume' button. Unfortunately, the DVD I popped into the player had one of those studio promotion segments that boots up automatically and it came on at a very high volume (something like +6db on what was already a loudly mastered opening). Well, I immediately ruptured a woofer and, thinking this was the only problem, removed it and sent it to Vandersteen for a repair.
A few months later I noticed that there was something wrong with the sound. I began working to track down what it was (this is another story that I will relay sometime soon in a open letter to Vandersteen). Since I knew there was something wrong, probably related to the above incident, I decided I really needed to test out all of my speakers. Alas, I have sent three speakers back to Vandersteen and will be receiving these back soon.
So, I would like to minimize the chances of this happening again. I've changed the way the Lexicon is set for volume (and I'm a little more careful about just popping in a DVD), but I believe that reworking my crossover settings would help ensure nothing is damaged in the future.
I have considered leaving the speakers at LARGE and setting the sub to 80Hz, or I could set the speakers to SMALL with a 80Hz cutoff and also set the sub to 80Hz. I'm not sure if there is any technical difference between those two, does anyone know the DC-1 well enough to know? Also, what would you all recommend?
I'd like to strike a nice balance between reproducing accurate sound and making sure the speakers are not driven too hard. Thanks for any replies (and, of course, if you have any other questions, let me know)!
- Aaron
"Some mornings, it's just not worth chewing through the leather straps"
-Emo Phillips
- Aaron
-Emo Phillips
