Crossover recommendations for Athena Point5
Discussion in 'Speakers & Subwoofers' started by Takin Nili, Nov 26, 2003.
  1. Takin Nili
    Takin Nili Auditioning
    Nov 25, 2003
    3
    Hi,
    I have the Athena Point5 speaker package and a matching AS-P300 subwoofer. The Athena website lists the frequency response of the Point5 speakers as follows:
    S.1 80Hz - 20KHz
    C.1 60Hz - 20KHz
    The subwoofer has its own base management dial that allows a setting tailored for the S.1. The S.1 setting is about 80Hz. The dial goes from 40-120Hz.
    I have configured the receiver to use small speakers. The HK-230 has a triple crossover system of its own for the front, center and surround speaker groups.
    What should I set the crossover frequency to on the receiver? Should I change the crossover frequency on the subwoofer? Thanks.
  2. Takin Nili
    Nov 25, 2003
    3
    I wanted to add that I found out that the AS-P300 has a direct low-level input that ignores the bass management and volume setting on the sub. Instead, it will take those settings directly from the receiver. This sounds like a good solution, the only caviat being that I need to trim the sub volume again.
    I would still appreciate an answer regarding the receiver crossover setting. I am leaning toward 120Hz at them moment.
  3. Takin Nili
    Nov 25, 2003
    3
    No Point5 owners out there?
