Brad E
- Jan 11, 2004
First off, I'm still waiting on my system to arrive.:frowning:
It should be this week though.
Anyways after doing a bunch of searching and reading, I'm now more confused than I was before. (If that's possible)
What I do understand is any frequency above my crossover point will go to the selected speaker. Any frequency below is diverted to the sub. That's about all I know.
Here's a list of my speakers.
4 JBL ND310II's Left/Right and Surrounds
Frequency Response= 37Hz - 20kHz
Crossover Frequency= 1000, 5000Hz
JBL EC35 Center Channel
Frequency Response= 75Hz - 20kHz
Crossover Frequency= 800Hz, 3200Hz
JBL PB12 Sub
My receiver is a H/K 7200 which has triple crossovers (L/R, CC, & surrounds) which come from the factory set at 100Hz.
Now ideally I would like to use my big 310's for bass as well as my sub.
So what should I do? I know the typical response is to set them at 75-80Hz. But that means that my 310's won't be using even close to their potential.
And should I use the same crossover setting for all speakers? Just asking because I couldn't find much info on the best crossover point for the center channel
Thanks for any help.
JBL PB12 Sub
