Kenneth Harden
- May 13, 2002
Having 2, 8-ohm drivers together (making either a 4 or 16-ohm load I guess) and then having a 8-ohm tweeter in the mix?
The amp would be able to handle any sort of load I threw at it (other than maybe a half-dozen 15" woofers).
Two of these (or similar 8-ohm driver):
http://www.partsexpress.com/pe/showd...number=295-300
One of these (or similar tweeter):
http://www.partsexpress.com/pe/showd...number=276-152
Used for a 2-way MTM design.
I don't know enough (well, anything!) about crossover design to know about making this work. Just want to know if it is reasonably feasible.
Thanks!
Thanks!
