Crossover for Energy Take 5 Main
Discussion in 'Speakers' started by Davin D, Jan 31, 2005.
  1. Davin D
    Davin D Agent
    Dec 8, 1998
    30
    One of my Take 2s in the Take 5 system has a bad crossover as nothing is getting to the woofer. The manual says it has a crossover point of 2.5khz, then it says Built-in High pass @ 90hz. Can anyone tell me where I can get such a crossover?
  2. Andrew Pratt
    Andrew Pratt Producer
    Dec 8, 1998
    3,806
    Your best bet is to take the cross over out and see if its something simple like a blown capacitor. If a cap is blown you'll see the end buldging or even broken. If that's the case its pretty easy to replace a cap. Finding a replacement crossover is going to be next to impossible as it would have to match the others perfectly and since its very likely just a cap it would be easy enough to repair the old one.
  3. Davin D
    Davin D Agent
    Dec 8, 1998
    30
    Andrew,
    Thanks for the reply. I'll take a look and see what I can tell.
  4. John Garcia
    Jun 24, 1999
    11,571
    24
    NorCal
    Try contacting Energy, they may replace it for you via a local dealer/service center. Even if they are out of warranty, some manufacturers still like to keep their customers happy.
  5. Brian Fellmeth
    Jul 30, 2000
    789
    How do you know its not the woofer itself thats blown ?
  6. Davin D
    Davin D Agent
    Dec 8, 1998
    30
    Brian,
    It's funny you bring that up. I never thought it possible. But, yesterday I hooked the speaker straight to an old boom-box I had in the garage and sure-enough no sound. Shows you how much I know about speaker design. I wonder if I can replace the woofer (if you could call it that in a take 2). This is for a system in my loft that my kids use to watch movies, so I don't want to spend a lot of money.
  7. Greg Thomas
    Greg Thomas Second Unit
    May 3, 1999
    438
    Call Energy, I blew a speaker in one for my Takes and they offered to send me a replacement woofer. I decided to send the whole speaker instead, just in case something else was wrong. The whole turnaround time was maybe a week to 10 days.
  8. Davin D
    Davin D Agent
    Dec 8, 1998
    30
    Greg,
    Thanks for the information. How much did they charge?
  9. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    Might be a good idea to also check if the woofer is connected.
  10. Davin D
    Davin D Agent
    Dec 8, 1998
    30
    Sorry Chu,
    I should clarify my earlier post. I actually removed the woofer from the enclosure and wired it to an old stereo and it was not working.
  11. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    That's DOA for sure [​IMG]
