Crossover for a DIY subwoofer (1 Viewer)
Bruce Chang
I'm running a 4 ohm illusion audio 15 inch subwoofer SVC model nd15 using a sherbourn 5/1500 bridged so about 800watts@4 ohms. What are some good crossovers for under 100? I was thinking about using my outaw audio 1050 reciver for a LPF, but usually an external x-over is better. What should I do?
Drew Eckhardt
Assuming the slope/cross-over point options don't offend you, the internal cross-over is the way to go because it will let you time-align your main speakers and sub-woofer.
On top of that, it's already paid for...
Bruce Chang
What do I do about the gain since the sub gain control on the outlaw 1050 is +-10db. I'm afraid that the sub would be too overpowering or vice versa. The X-30 has high pass and low pass which is good for my mains and sub, but that requires more rcas.
Greg_R
Portland, OR
Greg
This is a misconception. I run a Crown K2 (2500W/4ohm) at full gain into a dual DIY design. My receiver's LFE output setting is at +1. Your internal crossover should work fine...
Jeff_M
He's right... you need to change your signature. If people search for info on products that happen to be in your signature, your unrelated posts will show up in their results.
John Garcia
NorCal
As you can see from Jeff_M's post, however, you can put a link to your a list of your gear.
RobRWA123
