Crossover design
Discussion in 'Archived Threads 2001-2004' started by Stasulos, Oct 4, 2002.
  1. Stasulos
    Stasulos Stunt Coordinator
    Sep 9, 2002
    50
    I understand where the capacitors' and inductors' parameters come from (this link for example http://www.mhsoft.nl/spk_calc.asp#crossover), but how to calculate the resistors? How to understand where to put them?
    Can anybody give me some links to some advanced crossover designs please?
  2. Dave Poehlman
    Dave Poehlman Producer
    Mar 8, 2000
    3,813
    As long as both drivers are the same impedence rating, you shouldn't need any resistors.
    If you are incorporating a resistor, it's usually to damp the driver a bit and would be wired in series with that driver.
    IE: I have a 6 Ohm tweeter and an 8 Ohm woofer, I would wire a 2 Ohm resistor in series with the tweeter to make it an even 8 Ohms.
  3. Patrick Sun
    Patrick Sun Moderator
    Jun 30, 1999
    38,751
    482
    9,110
    Well, driver impedance is frequency-dependent, so you can't simply toss in an inline resistor on the lower rated driver to "raise" the overall impedance rating for the speaker.
    Resistors are used for padding down the tweeter or midrange, and also for baffle step compensation to smooth out the woofer's output in 4 pi space. Also, resistors are used to tame peaks in a driver's response (notch filters).
    Creating crossovers for a speaker system needs to address the overall response of the speaker and its drivers.
    It's simple to pop in some textbook filters for the drivers (which may or may not allow the speaker to sound good), but to get the most out of the drivers, you'll need some measurement data and good crossover design though process or programs to optimize the crossover for a particular speaker design.
  4. Greg Monfort
    Greg Monfort Supporting Actor
    May 30, 2000
    884
    Also, adding series resistance *reduces* damping since Qes increases. It's a common way to raise the Qt of a severely overdamped driver, such as is often used in prosound designs. Back to Filters 101, DP. [​IMG]
    WRT links, I don't recall ever seeing any that dig into filter design beyond either having an on-line calculator or publishing textbook filter formulas.
    GM
