rich r
- Jul 29, 2001
Im am new to the DIY scene and i have a few questions about crossover construction:
1. what is the best type of solder to use when joining components?? (Will any mixture of rosin-core solder work)
2. What type of adhesive should be used to mount the components to the masonite? (Is 2 part epoxy good)
3. How should the final built crossover be mounted to the enclosure? (again is 2 part epoxy good to use here)
thanks
In advance
thanks
In advance
