Crooked picture on my Sony KV-36HS20
Discussion in 'Archived Threads 2001-2004' started by Mike Grice, Feb 16, 2003.
  1. Mike Grice
    Mike Grice Auditioning
    Feb 4, 2003
    3
    Hi all-
    I bought this set back in August 01. I didn't notice the picture was slightly crooked (leaning towards the lower right) until I got a TIVO. As soon as I plugged the TIVO in, the problem was obvious. Any ideas as to what can be done to correct it?
    Thanks!
    Mike
  2. Steve Schaffer
    Steve Schaffer Producer
    Apr 15, 1999
    3,756
    Mike,
    If you delve far enough into the user video control menu you'll probably find an item called "tilt". Dig out the owner's manual and you'll probably find it. Screen tilt occurs on big direct view tvs due to the Earth's magnetic fields and there is a user adjustment for it though it's usually under "advanced settings" or "setup" menus.
