Crimp-on banana plugs?
Discussion in 'Archived Threads 2001-2004' started by Scott Kriefall, Aug 22, 2002.
  1. Scott Kriefall
    Scott Kriefall Second Unit
    Mar 9, 1999
    332
    SLC, Utah
    Scott
    I recently picked up the following crimp-on banana plugs from Radio Shack:
    [​IMG]
    After purchasing these, I realized that I have no idea how to attach them to the wire!
    I've read some discussion of crimp-on RCA plugs for interconnects, where a separate crimp tool is used to attach the plugs. Is the same true here?
    The Radio Shack salesdroid muttered something about using a pliers to attach the cable. But the doesn't really look like a viable solution...
  2. Dan Hine
    Dan Hine Screenwriter
    Oct 3, 2000
    1,312
    Scott,
    First you pull the rubber jacket off. Do this by pulling it toward the "back" of the plug. Then run the wire through the plastic piece and into a collar on the plug itself. Crimp that down (pliers can be used here if no crimp tool is available). The to finish up just slide the rubber jacket back up over the gold plug. Voila! Once you get the plastic piece off it will be fairly obvious. Enjoy.
    Dan Hine
  3. Scott Kriefall
    Mar 9, 1999
    332
    SLC, Utah
    Scott
    Thanks. I think I have it figured out now!
  4. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    if you've got a wire stripper then you'll find different size 'slots' where you can crimp. also if you're handy with a soldering iron and are careful of the plastic, you can further reinforce the connection.
  5. Roy Wallace
    Roy Wallace Stunt Coordinator
    Nov 17, 2001
    108
    Scott:
    I am using the same plugs. When I crimped the first one, it cracked in half. The metal seems quite brittle.
    I just soldered my 12GA wire into the ends without crimping and they seem to be holding up just fine. Be careful, though. The metal gets really, really hot!
    Good luck
    Roy
