Creating forms have a MySQL question
Discussion in 'Computers' started by Greg Haynes, Feb 23, 2004.
  1. Greg Haynes
    Greg Haynes Supporting Actor
    Oct 22, 1998
    577
    Client of mine would to create a simply section on her site to input client information. I can create the form for her to enter but I need help with storing the data. I know I need to create a mySQL db using my hosts cpanel, I started playing with it and starting creating fields but how do I save all the data that the user enters into the db. Bascially how do I connect to the db using Dreamweaver MX.
    I just need some simple steps on setting the db up and having the data stored. Thanks in advance.
  2. Greg Haynes
    Oct 22, 1998
    577
    I created a simply form with one textbox and a submit button. The database has been created with 2 fields with one field as an autonumber and the other a simply text field. The code is below with the form and so how do I have the text box assign to the field in my table. Do I need to write an SQL statement on website? If so how do assign an sql statement to the submit button.
    < !DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
    < html>
    < head>
    < title>Untitled Document
    < meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
    < /head>
    < body>
    < form name="form1" method="post" action="">
    < input type="text" name="textfield">
    < input type="submit" name="Submit" value="Submit">
    < /form>
    < /body>
    < /html>
  3. DaveF
    DaveF Moderator
    Mar 4, 2001
    21,990
    3,567
    9,110
    Catfisch Cinema
    Dave
    Greg, as with your search question, you will need to use server-side processing. You need some logic code using PHP, Perl, etc. to process the information sent by the form and insert it into the database. I'm just a hobbyist and haven't done any database or PHP work in a while, but I don't think there's any way to do this with straight HTML or javascript.
    That said, it's pretty easy with a little PHP code. The PHP and MySQL websites have lots of good documentation. I recommend doing some reading there.
