- Jul 19, 2002
I'm wondering if it would be feasible to use resistors to create a 6 ohm load on a capable receiver using 8ohm speakers, to squeeze that extra bit of power out.
I got this idea when looking at the stats of a receiver i'm thinking about buying that had a 35 watt jump from 8ohm to 6ohm.
I know a 35watt increase would only translate to about 1db of extra volume, and wouldn't make that much of a difference, and would also raise the THD, so it might not be to any advantage at all, even though the 6ohm THD of the receiver in question is still only .7%, which is less than the 1% 8ohm THD of my current receiver. I'm really asking this to see if my meager understanding of some basic electronic theory is correct.
If so, what resistors would you use to do it? and would you simply solder them to one end of your speaker wire?
