Crackling sound. May need a new sound card.
Discussion in 'Computers' started by Andres Munoz, Jul 17, 2006.
  1. Andres Munoz
    Andres Munoz Cinematographer
    Dec 21, 1999
    2,489
    I currently use the audio panel built into the motherboard. I have a Y cable which splits into two outputs: one for my headphones and the other goes into my HT receiver.
    I use my headphones most of the time so one day I started noticing this crackling sound in the background at all times (listening to MP3s, playing games, etc). At first I thought it was my headphones because they're wireless. I thought they were going bad. But it sounds the same when I play any audio through my HT receiver. The sound is not clean anymore. There's a lot of "garbage" going on in the background.
    I'm not sure what the problem is. I removed the Y cable and connected the PC directly to the HT receiver and directly to the headphones but the sound is still bad. I don't know if the motherboard audio panel is going bad or not. Any ideas what could be going on?
    Also, I started doing a little research here and out in the internet for the latest sound cards and the HDA X-Plosion 7.1 looks very interesting with the DDL and DTS Connect features. For those of you who own this card, can I get some feedback on it?
    Thank you all in advance.
  2. Rommel_L
    Rommel_L Second Unit
    Apr 25, 2000
    355
    Make sure you have the most up-to-date drivers for the sound card. Get rid of the Y-splitter and either directly connect the headphones or the a/v receiver. If you're still hearing the crackling sound then it might time to get a new sound card...
  3. Andres Munoz
    Dec 21, 1999
    2,489
    Also, as I explained before, I already did that.
  4. Rommel_L
    Apr 25, 2000
    355
    The built-in sound card still does need drivers. If you know the mobo brand and model you should be able to find the latest drivers for the built-in sound card.
  5. Andres Munoz
    Dec 21, 1999
    2,489
    I'll give it a try. Thanks.
