Crackling from new speaker. Is it broken?
Discussion in 'Archived Threads 2001-2004' started by Yohan Pamudji, Mar 10, 2002.
  1. Yohan Pamudji
    Yohan Pamudji Second Unit
    Apr 3, 2001
    491
    110
    I just got some new speakers, and while listening to "Sposa son disprezzata" off of The Sopranos soundtrack I hear crackling coming from my right speaker. The crackling is coming from the tweeter. So I swap speakers, keeping all other connections the same. I hear crackling from the same speaker, which I've now moved to the left. Just to make sure I'm not crazy I swap them back and the crackling moves correspondingly.
    Is this a busted tweeter, a tweeter cover that's too tight to where the tweeter is bumping up against it, or maybe an issue that'll be fixed with break-in?
  2. John F. Palacio
    John F. Palacio Supporting Actor
    Jan 6, 2002
    575
    Unfortunately this sounds like a bad driver, or possibly crossover.[​IMG]
  3. Yohan Pamudji
    Apr 3, 2001
    491
    110
    How could this be a crossover issue? I'm not knowledgable about crossovers so I'd like to know.
  4. Nikos
    Nikos Auditioning
    Jan 26, 2001
    10
    I had a crackling sound from one of my drivers and it turned out that the foam gasket that helps seal the driver to the baffle was broken. To my amazement, the majority of my drivers had the same problem. It turns out that the gaskets wrapped around the screws as the drivers were being installed from the factory. I was annoyed especially since each of these towers goes for $750 US and they're from a reputable company.
    I would remove the problematic driver and check it for any abnormalities.
    Nikos
  5. Yohan Pamudji
    Apr 3, 2001
    491
    110
    Nikos,
    Those towers wouldn't happen to be Paradigm Studio 80s, would they? That's what I'm having the crackling problem with.
  6. John F. Palacio
    Jan 6, 2002
    575
    "How could this be a crossover issue? I'm not knowledgable about crossovers so I'd like to know".
    Let's say a component in the crosover failed or is out of spec and is sending frequencies intended for the midrange to the tweeter or those intended for the woofer to the midrange. This would cause those drivers to "cry uncle" when hit hard by those frequencies.
