MikePeroni
- Sep 1, 2001
Hey all, running an Energy Take 5.2 set with a Integra 5.3 receiver.
First question: The Integra has adjustable x-over (80,100,120). What difference then does it make if you choose Large or Small in the set-up menu for speakers since you can set your own x-over.
Second : Why does the Energy manual tell you to set up the receiver to Large(for speakers) and Sub ON? Obviously the Take 2.2 sat. only goes down to 80hz at best...
Third : The sub has two different RCA inputs, 'x-over' and 'input'. One makes the volume and frequency control adjustable on the sub, and the other makesthe receiver control the freq. and volume for the sub. Which one should I use?
Any help would be appreciated as there are alot of ways to set this up, and Id like to know the correct way to do it... Mike
