Wes_R
- Sep 1, 2004
First forum post, and first "big" tv buy, hdtv projection.
Need help and suggestions..
Alright, ive narrowed it down to 2 selections the Toshiba 51H84 and 46H84. Both being bought from BestBuy.
(stop with the bestbuy flaming, i know, i know..)
My room is of dimensions 11.5ft x 11.5ft
Now, im trying to decide which model/size i should get that will be sufficent enough to view from short distances of say between 4ft-9ft without noticing any graphical/pixilation. Which would you recommend? Beause if the 46" is enough then, i can save a few hundred and buy that.
Also, the BB rep was pushing the Xbox Monster cables on me for like $60! I was like WTF! In order to get the hdtv compatibility, i would need the cables.. Do i really need them or are there any cheaper alternatives.. I dont wanna skimp out though, i want what i see in the magazines, good graphics..
Power supply protector.. Now what would you guys recommend i use to protect these babies? The rep recommended a $60 outlet protecter.. I was like WTF! again!
either way it goes, i got about 2100 to spend and that should include taxes, delivery, and warranty.
If you guys can help me decide on these options i would greatly appreciate it as it will save me money.
