BernieBl
- Nov 26, 2002
I hope that someone can answer my question.
This is not meant to start a discussion on the quality of Bose, but since I got this unit for cheap I am looking for an inexpensive solution until I can spend more on a quality piece.
So here is the question: This Bose subwoofer has 4 inputs from the receiver, 2 reds and 2 blacks (it drives two speakers internally). A friend of mine has an amp that only has 2 outputs, this amp is very close to what you will see here, http://www.smarthome.com/8275.html
Can I use such an amp to power the unit? And what would that be? 4 ohms or 8 ohms? How do I wire from the amp to the suwoofer?
Thanks for you time,
Bernie
Bernie
