Could One Use AVIA To Calibrate 6.1, 7.1??
Discussion in 'Archived Threads 2001-2004' started by Chuck C, Apr 13, 2002.
  1. Chuck C
    Chuck C Cinematographer
    Jan 6, 2001
    2,224
    if not, then how is it done?
    thanks
  2. Bill Kane
    Bill Kane Screenwriter
    Feb 5, 2001
    1,359
    Sound&Vision Home Theater Tune-Up, $15.00 at amazon.com, carries DD/Dts 5.1 AND 6.1 set-ups.
    There are other tone generating stratgies/discs, as you know.
  3. Chuck C
    Jan 6, 2001
    2,224
    the reason i asked is b/c my friend has 6.1 and wants to use my resources (avia and rs spl)...so now he has to get the s/v disc?
  4. Bill Kane
    Feb 5, 2001
    1,359
    chuck, what about this idea...let's say you calibrate 5.1 w/ Avia and SPL meter.
    Now the the mains, ctr, rear surrounds are equal in listening position output.
    So then you engage the receiver's internal test tones and adjust the last center surround or whatever he's using to the same level as one of the RS, using the meter.
    If it works, it doesnt matter the ABSOLUTE level rather the RELATIVE levels of the speakers
  5. Jeff Engel
    Jeff Engel Stunt Coordinator
    Feb 13, 2002
    205
    That's exactly how I did my calibration recently. I used avia to get the 5.1 calibrated, then I went into the receiver's test tones and noted the volume. I then went into the rear surrounds and adjusted them to the same "corrected" volume from the other speakers.
    Jeff
