JohnSer
- Dec 4, 2002
Kevin,
OK, FWIW, I went and tried this on my set-up. HK520 as pre/pro, Adcom 545II amp, and custom Peerless HDS439/Seas T25 speakers (about 84db/watt).
Test #1, Power amp on and receiver in standby
results: ear right to speaker - nothing from mid-woofer and just the very slightest hiss from tweeter. Confirmed with modified RS SPL meter. Getting only the slightest deflection at the most sensitive setting.
Test #2, Power amp on and receiver is off
results: same as above
Test #3, Power amp on and receiver is on, vol at min, source set to CD, which is using optical connection, CD player is off
results: ear right to speaker - very slight hum from mid-woofer, nothing detected from tweeter. Confirmed with SPL meter. Getting only the slightest deflection at the most sensitive setting.
Test #4, Power amp on and receiver is on, vol at -10 setting(very loud setting, I never listen at that), source set to CD, which is using optical connection, CD player is off
results: ear right to speaker - very slight hum from mid-woofer, nothing detected from tweeter. Confirmed with SPL meter. Getting only the slightest deflection at the most sensitive setting. This was a surprise, and will check latter with spl meter. I was expecting increased hiss. I suspect it is because the digital source, and because there is no bitstream lock, the receiver is muted. I will try an analog input, to see if that has different behavior.
PS: RS SPL mods are the ones on Eric Wallins site. It makes the meter more sensitive. Just touching the case or breathing can peg needle.
PSS: Ear was within an inch or two from driver. SPL meter within 1/2 inch of driver.
Gain: I pulled out service manuals for Adcom 545II (100W/8) and Adcom 555II (200W/8). Gain on both is 27db, all noise figures favor the higher output 555II. Both at each respected full output. What does it mean? Don't know, but don't have a 555II to plug in.
