CORK FLOORING for home theater
Discussion in 'Archived Threads 2001-2004' started by AaronG, Dec 7, 2001.
  1. AaronG
    AaronG Stunt Coordinator
    May 15, 2001
    185
    Hi guys,
    My wife and I are finishing the basement and building my home theater. I'm thinking of using cork flooring. Has anyone used this in their HT? One requirement is that the theater is semi-soundproof. What about using it on the walls in there as well? All suggestions and comments welcome!
    Aaron
  2. Dave Poehlman
    Dave Poehlman Producer
    Mar 8, 2000
    3,813
    I think cork would work great for sound abatement. If you can stand all that cork on the floor and the walls. You wont have to worry about missing the dart board. [​IMG]
    I saw the flooring done on HGTV once... it came out looking really nice.
  3. Kendal Kirk
    Kendal Kirk Stunt Coordinator
    Aug 15, 2001
    155
    I must say a cork floor is very elegant when installed and finished properly. It isn't hard, but when it is done wrong, it looks like crap!!!
    I think that if you do cork on the floor, you may want to try a carpet on the lower half of the walls. I have seen this combination with both hunter green and maroon and it looked beautiful!!!
    Good luck. . .
