Corel Like Program for Drawing to scale?
Discussion in 'After Hours Lounge (Off Topic)' started by DeathStar1, Oct 31, 2005.
  1. DeathStar1
    DeathStar1 Producer
    Dec 28, 2001
    3,267
    Hey all,
    I'm asking this question second hand here, so I hope I can get the point across.
    Is there a non memory intensive program like corel that can get a snap to grid type scale drawing done in the computer? Preferably a program that can be run on a laptop? Guy at work would like it for his part of the buisness and I thought I'd ask around to see what's available..
    Thanks!
  2. Christ Reynolds
    Christ Reynolds Producer
    May 6, 2002
    3,597
    CJ
    i'm not exactly sure what kind of drawing you are talking about (never used corel either), but gimp should be able to handle just about anything he needs, unless it is a specific function that it does not support.
    CJ
  3. MarkMel
    MarkMel Screenwriter
    Nov 19, 2003
    1,838
    106
    I've used Visio on occasion to make drawings to scale. It has annotations for architectural and engineering drawings.
