Cooling Fan
Discussion in 'Archived Threads 2001-2004' started by Dave Malo, Mar 8, 2002.
  1. Dave Malo
    Dave Malo Agent
    Aug 21, 2001
    28
    I have a mini fan hooked up to my receiver so when the receiver is turned on it automatically starts. Is there anyway that a thermostat can be hooked up so when a certain temperature is reach it would turn on. I noticed that I have an extra wire on the Fan, which I think can be used for this purpose.
  2. David Sorenson
    David Sorenson Stunt Coordinator
    Jan 19, 2001
    92
    You should be able to get a sensor somewhat like the old thermostats which could turn the fan on. I have a fan installed on the back of my entertainment center that is plugged into my receiver so when it is on, the fan is on. I'm still trying to tweat it quiet it down.
  3. Terry Wysocki
    Terry Wysocki Stunt Coordinator
    Nov 21, 2001
    69
    The third wire on a fan (of the 12volt variety) is usually used to provide RPM feedback to a computer motherboard. Use a 7.5 or 9 volt transformer from an old cordless phone or portable radio, etc. to create a very quiet fan.
