Coolest Thing I've Ever Seen! Anyone Ever Seen This?
Discussion in 'After Hours Lounge (Off Topic)' started by Dan**S, Jan 16, 2005.
  1. Dan**S
    Dan**S Auditioning
    Jan 16, 2005
    2
    I know that home theater is sound system, video, seating, etc. A friend of mine took this one step further by adding some sort of color changing candles to add to ambiance.
    Thought I would share what I thought was a neat idea...
    Has anyone else ever heard or seen a Lunacandle? And/or know how it works?
    I got an email from the people at this lunacandle . Thought I would share.
    1. go to the site and type the word: forumers under the Redeemable Code section and get 15% off the price.
    I just bought one
  2. mark alan
    mark alan Supporting Actor
    Nov 19, 2002
    620
    you're crazy if you use candles around expensive electronics. candles put out lots of crap into the air, and those fans in the equipment will pull it right in.
  3. David Galindo
    David Galindo Screenwriter
    Mar 30, 2003
    1,264
  4. Jeff Ulmer
    Jeff Ulmer Producer
    Aug 23, 1998
    5,584
    You can get a similar device for crystals or other glass wear, which is basically three LEDs in a base that are turned on and off. You put the crystals on the base. Far better than candles, especially around equipment.
  5. Dan**S
    Dan**S Auditioning
    Jan 16, 2005
    2
    I just thought that the candle was unique because it was triggered by being lit. It had no switch or wire, etc. Just a candle. But I understand the point about giving off soot, etc. Maybe it would be better off in the bed room. [​IMG]
