Cooking Question: Crispy Chicken Strips
Discussion in 'After Hours Lounge (Off Topic)' started by Brandon_T, Apr 17, 2005.
  1. Brandon_T
    Brandon_T Screenwriter
    Oct 3, 2000
    1,903
    I was wondering how do you make the crunchy chicken strips that you get at a place like Bennigans, or Applebees? I have made my own several times and they just come out slightly breaded and without much of the "crispy" part to them?
    I typically wash the chicken in milk then dip in flour and fry up, but it just isn't anywhere near the same. So I was wondering if anyone had any tips or recipes that yield better results. Thanks in advance.
    Brandon
  2. CRyan
    CRyan Screenwriter
    Feb 9, 1999
    1,239
    Use a beaten egg first of all to wet the chicken. You can double bread by going from egg to flour to egg to flour - fry. You can also do egg flour egg, and then fry wet. Try adding spices to the egg and to the flour - whatever you like - garlic powder, onion powder, pepper, paprika, salt, sugar.
    I usually cut one large breat into four strips. You should make 8 strips and do them several different ways to find the crispiness and taste you like.
    And use a fryer.
  3. Kevin Hewell
    Kevin Hewell Cinematographer
    Mar 28, 2003
    2,227
    122
    1,610
    [chef]Do a dusting of flour first to coat, shake off excess, dip in a mixture of beaten egg and milk (or just milk if you want to skip the added cholesterol), then dip it in the seasoned breading. Shake off the excess breading and drop it in oil heated to 325-350 degrees and cook until golden brown.[/chef]
    The first dusting of flour helps the egg/milk mixture adhere to the strips.
  4. Lynda-Marie
    Lynda-Marie Supporting Actor
    Jun 3, 2004
    762
    I thought most of how they got the things so crispy was that they used a deep fryer.
    But fried chicken, as Southerners prefer it, is usually done with cast iron cooking skillets.
  5. aaron campbell
    aaron campbell Second Unit
    Jan 11, 2000
    281
    Buttermilk. It's the key to a good breading for fried chicken.
  6. Philip_G
    Philip_G Producer
    Nov 13, 2000
    5,030
    I'd go with breadcrumbs, the fine ground type in a can, with egg.
  7. Tim Hoover
    Tim Hoover Screenwriter
    May 27, 2001
    1,422
    We use Captain Crunch cereal for chicken breading. It's fantastic!!!
  8. Kevin Hewell
    Mar 28, 2003
    2,227
    122
    1,610
    Also, restaurants use actual chicken tenders for, well, chicken tenders, not cut up breasts. So, if you want them like in the restaurant, use actual chicken tenders.
  9. Philip_G
    Philip_G Producer
    Nov 13, 2000
    5,030
    what are chicken tenders exactly?
  10. John_Stra
    John_Stra Extra
    May 10, 2004
    19
    Use a cast iron skillet.. and try different breading
  11. Matt Souza
    Matt Souza Agent
    Mar 7, 2002
    38
  12. Philip_G
    Philip_G Producer
    Nov 13, 2000
    5,030
    I didn't know chickens HAD tenderloins.
  13. Russell G
    Russell G Fake Shemp
    Sep 20, 2002
    11,441
    672
    9,110
    Deadmonton
    Russell
    Cast iron skillet, okay, how much oil? Are you still deep frying?
  14. Bob-N
    Bob-N Supporting Actor
    Jul 26, 2001
    915
    From my observations, I think it's about halfway up when the pan is full of chicken. If I had to guess, I'd say about 1/2-1" deep, not quite deep frying depending on how big your pieces and skillet are.
    I think that in order to get crispy crunchy style chicken, you either have to do the egg/flour thing a few times or use some sort of wet batter like you would see on tempura. Dunno for sure.
  15. DaveMcS
    DaveMcS Second Unit
    Jan 30, 2001
    316
    Parts is parts....FUSED !!
    [​IMG]
  16. LewB
    LewB Screenwriter
    Feb 11, 2002
    1,282
    Some personal experience, some Alton Brown (Good Eats):
    1 - Flour then egg wash then bread crumbs (I use plain but have heard raves about Panko Japanese bread crumbs). You can also season the flour with salt and pepper or whatever else you like.
    2 - Make sure the fat in the pan is hot before putting the stuff in. If the fat isn't hot, it soaks into the food. You can take the temp and make sure it's around 360 F. I usually throw an egg/bread crumb in first. I figure the oil is hot when it see the crumb bubbling.
    3 - Don't use paper towel to blot the food when it's done. That just holds the oil close to the food and allows it to soak in. Drain on a rack of some sort over a tray or pan.
  17. Jeff Gatie
    Jeff Gatie Lead Actor
    Aug 19, 2002
    6,531
    15
    I make what I call "Southern Fried Chicken Tenders" using the following recipe.
    Cut chicken breasts into strips (or use tenders). Soak in milk (or buttermilk). Put a few cups of AP flour in a container with a cover (I use those disposable Ziplock/Glad plastic containers). Make sure the container is deep and wide enough to hold around 5-6 tenders at a time. Season the flour with salt, pepper, Old Bay and whatever else you want (I use Emeril's Essence). Move the tenders from the milk to the flour. Cover the container and shake to coat the pieces. Move the pieces back into the milk and coat again. Repeat the flour step. This gives the coating a thickness similar to southern fried chicken. Have a chicken fryer (cast iron skillet, I use a Le Cruset which has a ceramic coating) ready with 1/2" to 3/4" of vegetable or peanut oil at 360 degrees (get a fry thermometer, temp is important). Fry on both sides until golden brown and crispy, turning once. The strips should just touch the bottom of the fryer. Remember to maintain the heat and do not overcrowd (5-6 strips at a time). If you want, save a couple tablespoons of the oil for a roux (flour and oil) to make a milk gravy for dipping (2 TBS flour, 2 TBS oil in pan cook flour until rawness goes away, stir in 2 cups milk and allow to thicken over medium heat, add salt and pepper).
  18. Vincent_S
    Vincent_S Second Unit
    Nov 29, 2002
    450
    I'm hungry now[​IMG] Thanks guys/gals[​IMG]
  19. Brandon_T
    Oct 3, 2000
    1,903
    Thank you all for the wonderful tips and suggestions, I will be giving them a try in the next couple of days! [​IMG]
  20. Jeff Gatie
    Aug 19, 2002
    6,531
    15
    Good luck Brandon. I have to recommend a fry thermometer again. Soggy breading is usually due to the oil not being hot enough or losing it's heat due to overcrowding. The secret to good frying is to have the oil hot enough to cause moisture to steam out of the the food so the oil is kept from soaking in, but not so hot that it burns the outside before cooking the inside. That way the outside is crisp and the inside is still moist and juicy and the food is not greasy at all. Only a thermometer can do this right.
    By the way, the recipe I gave above is also the way I do Chicken Fried Steak. Get some small chuck steaks, pound them thin, soak in buttermilk and flour twice, then fry at 360 deg. Make the milk gravy and proceed to inhale the cholesterol. MMMMMMMM good!
