Cookie Problems
Discussion in 'Archived Threads 2001-2004' started by RudyN, Feb 2, 2003.
  1. RudyN
    RudyN Supporting Actor
    Sep 12, 2002
    586
    Mundelein, IL
    Rudy Nunez
    For the past 2 days, whenever I come to the forums, I have to log myself in. I have it set so it is supposed to automatically log me in, and I never log out when I leave. I haven't changed any settings lately, and even checked my Control Panel to make sure all the settings are correct and it continues to happen. Is anyone else having this problem? Any advice for what I should try? Thanks.
    Rudy
  2. george kaplan
    george kaplan Executive Producer
    Mar 14, 2001
    13,063
    2
    Yeah, I'm having the same thing, FWIW.
  3. Qui-Gon John
    Qui-Gon John Producer
    Oct 2, 2000
    3,532
    110
    I have had a similar problem happen a few times during the last couple of weeks. Except I am usually already logged in when I first come her, but after doing some extensive reading and/or posting, all of a sudden I am logged out, and can't post. I then have to log back in, even though I never actually did click on any logout screen.
  4. Parker Clack
    Jun 30, 1997
    12,220
    75
    9,110
    Kansas City, MO
    Parker
    John:
    Your problem was related to the fact that you had the "Automatically login" and "Browse the board with cookies" enabled. That will get you timed out. I disabled the "Browse the board with cookies". See if that helps.
    Rudy and george:
    There is obviously something set on your PC that is removing your cookie. You might check your cookies directory and see if you have more than one copy of a cookie for hometheaterforum.com as they might be competing with each other. If you only have one copy try logging out and then log back in and this will reset your cookie for you. Something might have gotten screwed up with the present cookie that you are using.
    Parker
  5. Qui-Gon John
    Oct 2, 2000
    3,532
    110
    Parker, it just happened to me again. I did not change the settings that you changed for me. One thing I did notice, but like I said I left it alone, since you made that change, links that I've already viewed on prior visits, like title threads and the page numbers for the threads, do not show up red anymore. The red/yellow envelope icon has been owrking properly however.
