Converting Optical to Coax?
Discussion in 'Archived Threads 2001-2004' started by Ron-P, Oct 8, 2001.
  1. Ron-P
    Ron-P Producer
    Jul 25, 2000
    6,284
    7
    Ron
    I would like to pick up the Pani RP-56 Progressive Player but it only has an optical out, I am currently using coax.
    Is it possible to buy a converter box/plug so I can use the optical connnection with my coax cable?
    Peace Out~ [​IMG]
    http://home.earthlink.net/~peregrinefalcon
  2. BryanZ
    BryanZ Screenwriter
    Dec 18, 2000
    1,214
    110
  3. Kimmo Jaskari
    Kimmo Jaskari Screenwriter
    Feb 27, 2000
    1,528
    This has come up before a few times... but yes there are converters. Search for something like "digital optical coaxial converter" on Google and you should find several different options.
    /Kimmo
  4. Jeff Hipps
    Jeff Hipps Stunt Coordinator
    Feb 2, 1999
    194
  5. Zbigniew
    Zbigniew Stunt Coordinator
    Jan 8, 2000
    185
    www.midiman.com (just updating their page); they have 2 models, converts either Toslink or Coax into Coax and Toslink; search via google for resellers - you can get them very cheap.
    If you want a very good digital crossconnect, look at www.nirvis.com - DSX.
    _zjt
  6. Vin
    Vin Supporting Actor
    Oct 23, 2000
    546
  7. Kevin C Brown
    Kevin C Brown Producer
    Aug 3, 2000
    5,712
    5,110
    Both mcmelectronics.com and partsexpress.com have them for ~$15 plus the AC adapter.
