Converting 4ohm speaker?
Discussion in 'Speakers' started by HarryPluta, Feb 12, 2004.
  1. HarryPluta
    HarryPluta Auditioning
    Feb 9, 2004
    5
    I am still trying to figure out a short term speaker system to marry to a Yamaha RX-V1400 receiver. I have listened to a whole lot of speaker systems and at this point am leaning toward a Klipsch setup with a BIC sub-woofer.
    However, this may take a while to fund, in the mean-time I was wondering.....
    I have a set of Peavey Phase Reference Studio monitors (PRM 310S) and the matching Phase Reference center channel speaker (PRM225). These came out of my old R&R recording studio and are very clean and flat sounding. I would like to use them as the mains and center until I could build up a complete Klipsch system.
    The main issue is that the PRM225 is a 4 ohm and the PRM310S's are 8 ohm. In the studio it wasn't a problem as they each ran on a seperate power amp, but here I want to drive them from the Yamaha.
    Suggestions?
    -Harry
  2. TimRP
    TimRP Stunt Coordinator
    Feb 9, 2004
    115
    I feel you will be just fine with a 4ohm center, the yamaha should keep up with it just fine.
  3. John S
    John S Producer
    Nov 4, 2003
    5,460
    Yes, one 4ohm load on one channel, most likely will make no difference at all, as long as you calibrate.
