Convert HiDef to VGA help
Discussion in 'Archived Threads 2001-2004' started by Robert Ma, Dec 2, 2001.
  1. Robert Ma
    Robert Ma Second Unit
    Jun 18, 2001
    368
    Okay, I got my XBox and I need to get progressive output onto my VGA monitor.
    The XBox HiDef hook up is three color cables. I guess its like component....don't know for sure since I never used hidef stuff before.
    Now, I'm turning to the experts to see if there is a product I can use to convert the signal to VGA and plug my monitor in without signal loss.
    Bob
  2. John Kotches
    John Kotches Cinematographer
    Mar 14, 2000
    2,635
    Key Digital makes component video to VGA transcoders, check them out at http://www.keydigital.com
    There are undoubtedly other solutions on the market, and likely less expensive than the Key Digital ones. They're (the ones from Key Digital) the brand I'm familiar with.
  3. Robert Ma
    Jun 18, 2001
    368
  4. Dennis Nicholls
    Dennis Nicholls Lead Actor
    Oct 5, 1998
    8,994
    348
    9,110
    Boise, ID
    Dennis
    I've purchased both the Key Digital and the Audio Authority YPrPb to VGA converters for playing my progressive scan player on my Marquee 8501LC. The AA seems to work better than the KD in my application (better brightness range).
  5. Robert Ma
    Jun 18, 2001
    368
