DanielM
- Jul 5, 2002
I recently had a tech over to work on my tv ( warranty )
the convergence was so bad that just about everything had red or blue lines and overscan was pretty bad. he was able to fix the overscan and most of the convergence HOWEVER its still not 100% imho...for instance movie credits white text black background the text has blue haloing..an other example is the D*ll comp commercials the black text has some red haloing...the tech said this was as good as it gets and is within spec so?? is this the best Im gonna get or can it be 100% the tech did spend some time in service mode fixing the convergence so??? he also indicated that if I called the manf that they may refuse anymore work as he is reporting to them that the tv is within spec
