Convergence On old 3 tube projector
Discussion in 'Home Theater Projects' started by JohnGryskiewicz, May 3, 2005.
  1. JohnGryskiewicz
    JohnGryskiewicz Auditioning
    May 3, 2005
    Ok I am a first time projector owner and have a what I think is a difficult question. I got this projector for free because it was old. It is a Zenith Pro 851x which from what I have seen on the internet I think it is also like a Runco 750. Anyways it is the old style projector with 3 color tubes. We mounted it and the picture was pretty good but my roommate and I decided to tweak the settings a little more to make the picture better and it worked initially but then we managed to screw it up pretty bad. All three pictures are quite a bit off of each other.
    We obviously messed with the convergence including the skew and bow and pretty much everything else. If anybody has any tips or tricks to do this in a more simple way please respond. Our plan right now is to get the center tube image lined up and then adjust the other two to match. We have test patterns so we are going to try and do the adjustments using that. Any usefull tips would be appreciated. Thanks, John
  2. Stephen Hopkins
    Stephen Hopkins HW Reviewer
    Jul 19, 2002
    2,598
    If the projector was free why not spring a couple hundered dollars for an ISF calibration? It'll give you the best possible picture possible.
  3. Bryan Michael
    Bryan Michael Supporting Actor
    Mar 2, 2002
    564
    seccond the isf it is 300-500 and it will look awsome just make sure your bulbs are in good shape they say a 3 tube is like driveing a performance auto they are the best.
  4. ThomasW
    ThomasW Cinematographer
    Nov 6, 1999
    2,282
  5. Tom Rosback
    Tom Rosback Stunt Coordinator
    Jun 7, 2000
    119
    Try to find a dealer setup manual online. crtcinema.com is a good place to start. Follow the manual's instructions to the letter, and you'll be amazed at what this thing will do.
