Control A/V Unit from Computer (via RS-232)
Discussion in 'Computers' started by Bill Bradstreet, Aug 16, 2005.
  1. Bill Bradstreet
    Bill Bradstreet Stunt Coordinator
    Jan 7, 2001
    149
    I've been doing some searching, but I haven't found a good answer yet.
    My wife is visually impaired and finds it very easy to control our Audiotron via the web interface. I want to see if I can get our Outlaw 950 (which has an RS-232 port on it) set up with something similar. I'm thinking I'll put an old computer on the top of my A/V rack with a serial cable to connect to the 950.
    The problem is, I haven't found any software that will let me interface with my 950.
    For background, Crestron sells products to do this ... for $1,400 for the hardware and then you pay someone to do the programming. I'm hoping for a cheaper solution than this. [​IMG]
    Any ideas would be helpful!
    Thanks...
  2. Parker Clack
    Jun 30, 1997
    12,220
    75
    9,110
    Kansas City, MO
    Parker
    Bill:
    I would give the guys at Outlaw Audio a call and ask them what you can do with the RS-232 port and they have recommendations from other owners that have set up something similar.
    Parker
  3. Bill Bradstreet
    Jan 7, 2001
    149
    Thanks Parker. I have already posted on their forum as a suggestion for new products, but I haven't asked them that question... good idea.
  4. Grant B
    Grant B Producer
    Mar 29, 2000
    3,210
    There has been quite a bit done with the RS232 protocol controlling sony receivers and megachangers, not sure if outlaw uses the same
    Try Agoraquest for quite a bit of info and I put the link below that is for some SW developed for the DVD player
    http://www.agoraquest.com/viewtopic....12060&forum=50
  5. Glenn Overholt
    Glenn Overholt Producer
    Mar 24, 1999
    4,203
    I don't know about the receivers, but the changers that have it state that it is "reserved for future use" - but that is a load.
    Someone does have a professional unit so you can tie a changer into a PC, but it is pricey. Happy searching!
    Oh, and let us know.
    Glenn
