Cagri
- Dec 18, 2002
i have been reading the old threads for the last couple of hours and read in one of them someone quoting
When doing the calibration you'll also start out by lowering the contrast all the way down. If you try to adjust the brightness control with the contrast set at the (default) high setting then you risk ruining your TV.Is this correct for all types of TVs or only for RPTVs, I mean the risk of ruining the set via adjusting the brightness when the contrast set high? If so why don't the manufactuters put any warning against doing so in the manuals? I did several adjustments as such and I am quiet worried about having caused any damage to my set although there isn't anything wrong that I can see of...
