continuous cd burning problems...
Discussion in 'Archived Threads 2001-2004' started by Seungsoo Hwang, Dec 3, 2001.
  1. Seungsoo Hwang
    Seungsoo Hwang Stunt Coordinator
    Aug 6, 1999
    204
    Hi, I am having some trouble burning audio cds, specifically the continous mix type (like a dj mix). Ive tried both Fuerio and Nero, Fuerio with the remove pause between markers option and Nero by changing the space between tracks to 0 seconds (do they not have a "no gap" option? Changing individual tracks is really annoying). Anyways, ive burned a couple of different discs, and while there isnt the 2 second gap anymore, you can still tell that the "transition" is happening. Kind of an annoying skip to the next track, like a half-hearted attempt at continuation (sorry for the crappy description, I hope you get what im saying, its not a smooth transition, kinda jerky). Anyone know what is going on, rememdies?
    TDK 24/10/40 burner, 16x and 24x speeds used.
    thanks
  2. Kevin P
    Kevin P Screenwriter
    Jan 18, 1999
    1,439
    Have you tried the "disc at once" (as opposed to "track at once") option? This causes the whole CD to be burned in a continuous stream rather than one track at a time, which should eliminate any gaps.
    KJP
